Hi all. Long time lurker first time poster. Great sight will introduce myself after post.
I have been doing ceilings non stop for some some time now. The way we do it when dealing w reveal cuts is with a two man team. Thers a guy on the ceiling, he throws numbers and does the reveal cut score.
Im usually on the ground as cut man altough we have been mixing it up lately. im assuming your working with a 2x2 tile.
Top guy will throw a number say 16.25. This measurment will be from the inside of the wall angle to the outside of the paralell T
I will pull 16.25 with my tape and w my tape hand as a guide score the whole tile w my tape. I will then cut on the scored line. 2 notes here this will take some practice to get as good as a straight edge and If u decide to do this, tape up your guide finger as the tile will rip u up pretty good after a few cuts.
hand the tile back to top man or go back up to the ceiling and drop the tile. have the factory reveal edge dropped and place your cut edge in the wall angle. AFter making sure your factory reveals are square take the blade and score the tile along the wall angle. As previously mentioned by another poster there is a chance the wall is not square. do not worry about this as the wall angle is hugging the curve of the wall as well. When scoring the tile u dont need much just enough for the cut man to see and follow as a guide. I cant stress how important it is to have this score dead on w the wall angle for the entire run of the tile.
Pass the tile back to cut man or come back down. ideally u have a little work bench set up. i work off of 2 horses w the box of tile on my right and a tile I use as a cut board on my left. u will want a cut board. place the tile your cutting on the cut board. depending on what type of grid your using 1/2" or 9/16" you should have any where from .25" -.5" of tile from where you first cut to where the new score mark on the tile is. With your blade follow the score mark on the tile. Take it slow at first untill you get the feel of cutting in the score. You want to go about half way into the tile. Again youll get the feel for it depending on what your using. Now the trick. you will see the two facory edges on the ends of your cut edge. lay your knife onto its side and with a little bit of angeling your blade should line up almost perfectly w the factoy lips. Pull your blade down the entire length it may take a few strokes to get through. never force the cut material out if it doesnt just come out you may have to go a little deeper on the top or the side. again you will be able to feel where you will need to go deeper. The cut board will act as the guide for your knife wich is primarily why i use it and i prefer a tile because its smooth and flat.
Another few notes, if you cant be spot on with the depth of the reveal cut it is better to be a little on the deeper side. as you have 3 other sides holding the tile up and going a little deeper will allow you to place the tile w perfectly even reveals all the way around. it is important to have sharp blades in your knife for both the score man the cut man as a dull one will just pull the tile apart rather then cut it. We also find it nice to keep baby wipes on hand as they clean the tiles beautifully should the become smudged and we use them to keep the hands clean so we dont smudge them.
I know its long and does go through every step but i tried to be as clear as i could. As long as I was able to get all my points through as i clearly as i tried to, this should work perfectly for you. These cuts do take time and there realy is no shorter way if you want the reveal to come out smooth
Good Luck
