We have very few houses on crawl in my area, so I haven't dealt with this problem before.
I have a crawl space to encapsulate, but it is too shallow for anyone to actually crawl in there. I need to spray foam the outside walls of the crawl. My spray foam guy says no problem, just cut me a slot out of the subfloor about 18" wide near the outside walls and I can spray it from above.
Sounds reasonable. Now the subfloor is 1x on the diagonal. Cutting an 18" slot will leave a bunch of board ends hanging unsupported. Do I need/want to add blocking to support them? Do I need/want to replace the boards I cut out? Is any of it necessary? There will be a second layer of 3/4" ply subfloor, as there was before. Finish floor will be click LVT on top of the plywood.
I'm guessing there is a standard practice in parts of the country where crawls are common.
