1 - 20 of 45 Posts
Artisan Carpentry
I have a set of 12 elliptical corners I made for 6 arched openings in a remodel I'm working on. These are a close match to an existing opening.
Took a few process pics. I started with 5x9" blanks of 1/2" ply. Traced the pattern and rough cut the curves with the band saw:
Artisan Carpentry
Discussion Starter · #2 ·
The middle of the sandwich is an L-shaped frame of a vertical 1x block and a horizontal piece of 1/2" ply. An extra backing block was added in the middle of the curve for a total of 5 pieces.
I did the glue up with the ends of the "L" extending beyond the points of the curves and trimmed them flush on the bandsaw the next day. I do the glue up over parchment paper (bakers wax paper) to keep from gluing stuff to my bench.
Will install them on Monday and get to rockin'...
I love the stuff you do Brian. Interesting and thought out.
You posting pics of the finished openings I hope?
I had an old timer show me some method of making ellipses with a board and 2 nails. Interesting, but for me I use my wide format mylar plotter to make any pattern I wish.
Artisan Carpentry
Thanks Sir,
There are plenty of other ways to do it, but this should work. The "arches" are flat-topped... so not true ellipses. I plan to use hot water on 1/4" rock to bend them. Will do the arches this week (and the bath, laundry, mudroom,etc).
Later,
Bass
Maker of fine kindling
Looks like fun Bass
Glue and staples not ample for you?
Artisan Carpentry
The pseudo-elliptical arch gig got going this week. Installed the corner frames, and got to rockin'.
I found that 1/4" rock soaked with hot water would not bend that tight, so I scored the backs to get the bend.
Artisan Carpentry
The elliptical curve starts as a tight turn then flattens out. I scored for the bend on a graduated interval to match the curve. I did a gentle snap on each score line with the rip perched on a stack of scrap with a work table supporting the overhanging end. I also still got the piece wet too. I used PL Premium to deal with gluing wet rock.
I started at each end of the arch with two separate pieces of rock, overlapping them on the head and cut the overlap to splice. This eliminates the guess work on how long to cut the pieces with the bend. The rock is double layered and the second layer splice is off set from the first.
Lookin good Bass!
How long did you soak the back of the rock? I've found you have to give it a half hour dwell time to soak in..
Lookin good bass.
Im excited for the finished product, it should come out good.
Reactions: basswood
Artisan Carpentry
Discussion Starter · #20 ·
Lookin good Bass!
I think in this case, the rock was old stock (slow economy and slow selling item) and had hardened. Stiff and brittle... defeats the purpose of using the stuff. I let is soak a while and used it as a "lid" on a bucket of hot water to keep it "steaming" in hot vapor.
Then I resorted to the scoring. This was such a tight radius (3") that even the flex bead did not want to bend it.
Made it work though.
Cheers,
Bass
1 - 20 of 45 Posts
