avenge said:They make bullnose blades for wet saws.
How many do you have to make? A granite shop would do them up for you.
The profile wheels tend to get expensive if you dont use them enough. Making the bullnose is easy, polishing it up to match is the time consuming part.
About 75 pieces. I have an employee who would do a good job, but I'll also ask one of the local shops - you never know.How many pieces do you have to make? Only a few ?
Smoothly drag the tile across the wet saw blade to round over a bit. Belt sand a little more material off then finish with pads. Saves on polishing pads.
