cutting a hole in a cast iron sink.
10325 Views 35 Replies 11 Participants Last post by  Plbgbutcrack
I want to add a soap dispenser to the kitchen sink, but there is no factory hole available. I'll need probably a 3/4"-1" hole. I'll check it out when I buy the dispenser. Would a carbide hole saw and cutting fluid do the job without cracking the sink?
1 - 20 of 36 Posts
Yep, start on a 45 degree angle until you get a groove then slowly stand it up.
It will fvck a step bit in a hurry.
Didn't it say cast iron did he delete that or was I just seeing things?
I saw A Hole in the thread title and had to check it out.
But seriously, I wouldn't risk it. I would use the Relton PC-20 1-1/4" Porcelain Cutting Hole Saw Kit. It's not cheap, but nothing that is worth anything is.
http://www.etoolsrus.com/browse.cfm/4,5496.html
And I found out about it on the Rigid forum a few years back. The member "plumber rick" had a thread on it. I can't link it due to CT rules, but a Google search will get ya there.
It's in the thread title.
Ok, I think with the porcelain on top your going to have a hard time not cracking it.
Beings how we don't know what material he's trying to drill, I can't answer the question.
cast iron
And I found out about it on the Rigid forum a few years back. The member "plumber rick" had a thread on it. I can't link it do to CT rules, but a google search will get ya there.
Oh that's fancy!
It always said cast.
That thing is pretty slick, but a little more than I want to throw at a one time tool. I'm still going to consider the carbide hole saw though. I would probably need a diamond pilot bit to get through the porcelain.
Cheaper than replacing the sink.
Plus you will have it for future use.
I wouldn't bother with the pilot, but if you have a diamond hole saw that would be great for getting through the enamel.
Just take a chisel to it and get it overwith. :shutup:
I have cut hundreds of holes into cast iron soil pipes for saddle with just bi metal joke saws and a little cutting oil. It should be just as easy on a cast iron sink.
Did you mean jigsaw? What would keep it from chipping the enamel?
Cast iron stink stacks are not coated in enamel and cosmetics never comes into play.
If your worried about dulling your cutter going though the enamel Drill from the back till you hit enamel then punch the enamel through from top. I'm sure there's gonna be a flange at least 3/8" around the insert so if it chips a little no big deal.
1 - 20 of 36 Posts
