1 - 20 of 36 Posts
Ok, this is my first post so bear with me. I'm still a little new to this whole internet as a means of having professional questions answered hah.
I'm a tile sub on a remodel in Houston, Texas, the client is having a bathroom remodeled. Part of the remodel is taking an existing coffin shower and creating a curb-less shower in it's place. The shower is going to have a 1/4" slope per foot spanning 60 inches. Here is where the question comes in. The sub doing the shower work is going to cut the slope out of the foundation, I've never seen this done on a on commercial site. Is this the normal way you would go about putting in a curb-less shower? It is by all means easier on me doing the tile work to have it done this way but the residential foundation is only 6 inches thick on a single story home like this.
I just don't want an inspector to come through here and say it isn't up to code then the contractor or owner expect me to redo all the tile.
Any help is appreciated!
Eater of sins.
Doer of...things...stuff...
Sound like there is cause for your concern there.
Grinding the slab is done all the time or even demo'ing the slab is done but never the foundation wall without having a permitted plan to address the possible consequences of cutting into foundation.
I am not of much help but what the hell? I am edging in to 2000 posts.
Andy.
Andy.
Thank you for the quick reply! I'm nearly positive that if he ends up going this route he will get a permit. The contractor is someone I've known for a long time and have never see him not have proper permits on anything he puts his name too. He's a real by the book ass kicker. I suppose I should leave that up to him since I'm just the tile guy, but what's the harm in asking for a few other opinions?
Anywho, the shower actually won't be on the foundation wall, it will be about 3 feet from it on the highest point, and 8 feet on its deepest point. Anyone else done something like this?
Andy.
Your post was very helpful!
Discussion Starter · #11 ·
I'm sorry for asking but I'm curious. What kind of problems could arise from cutting the slab instead of refilling it with the slope? Would it be a problem structurally or a code problem? I know code is different everywhere but you're welcome to chime in with hypotheses anyway.
Do you know what style drain is being installed and its location relative to the existing? Most cureless showers are a single slope at ¼" in 12". If it is going to be a new lineal drain a replumb will be needed, might as well cut the floor.
You can mortar a pre sloped pan or a dry pack over the existing. Problem I see with this will be the drain.
If it is a multi slope, the floor can be ground to meet the (assumed) center drain. It will still need to be ¼" in 12".
No matter how it is done, make sure you waterproof the pan.
Tom
Discussion Starter · #14 ·
Tom
Good point, it's going to have a linear trench drain at the wall of the shower under the fixture.
Discussion Starter · #20 ·
Forgive me if this is OT, but why would a slab have tensioned cables in it$ I'm not familiar with that.
I've never really seen it done in residential construction, although calling a buddy he says that it's actually fairly common. With Houston having shifting clay soil, putting tension on the concrete will help prevent it from cracking.
I'm not really well educated on foundations, but it is very interesting.
1 - 20 of 36 Posts
