1 - 15 of 15 Posts
Boondockian
What are you calling a cripple exactly?
Cripples are studs that don't go the full wall height, normally found above and below window and door openings.
Fine Handcrafted Opinions
That's what I call cripples too, but I've run into people who call trimmers cripples and other weird stuff, so I was just making sure.
Not sure why the answer to the op's question wouldn't be to just continue the layout on the wall. Probably 16" oc.
Boondockian
Thats what I normally do as well continue the wall layout. However, I have run across situations(interior remodeling, non-load bearing)) where the walls end at door openings and seperate panels are framed above the door as fillers.
Boondockian
Trimmers in the diagram are called jack studs here. Cripples are the same.
Tom
I call them jacks as well. Thats just a diagram I googled up showing cripples, not something I use.
Artist and not a curator
huh? Never even occurred to me not to go back to a stud and continue layout, any other way is more work for you and every other trade behind.
Remodel
On a remodel, you may have an opening between room with the ceiling continuous through the opening. If you want to put a door there, it's just a bit of framing you can pop together on the floor and then put in place. No matter where you put the cripple, it's off the 16"OC in one direction or another, so usually you just put it in the middle.
1 - 15 of 15 Posts
