I'd recommend closer to 4" of stone. Rebar is probably unnecessary--how large is the space?
I agree, definitely not much extra expense or labor in that. The reason I'm considering skipping rebar is that access to send concrete into the space is very tricky and I may need to rolls wheelbarrow across to move the first 1/3 of the concrete. Probably a better way to do it but my experience with pour logistics is zero. I plan to hire someone to help me and float it out. If I attempt this alone I'll surely make a mess of it. Being a storage hole, really wouldn't be huge deal if it was sloppy but I'd have to live with it forever.brhokel606 said:I understand the delemia, but no rebar in concrete is a big no no in my book, especially at my own house. The rebar helps to keep the concrete together if it cracks and I would never take the chance with out it. Small cost in the grand scheme of things really.
We have done a few, take out a window and I mean totally take it out and just put in a new window after, that is what we normally do. We used 5 gallon buckets, filled outside and brought in through window. Sucked but is was a shelf basement on the last one and could not get enough of an angle to run concrete down a chute. Otherwise we normally just make a chute to bring it in.I agree, definitely not much extra expense or labor in that. The reason I'm considering skipping rebar is that access to send concrete into the space is very tricky and I may need to rolls wheelbarrow across to move the first 1/3 of the concrete. Probably a better way to do it but my experience with pour logistics is zero. I plan to hire someone to help me and float it out. If I attempt this alone I'll surely make a mess of it. Being a storage hole, really wouldn't be huge deal if it was sloppy but I'd have to live with it forever.
LOL, exactly. Have concrete truck put on chutes to get u close. Make a ramp through that hole, use a concrete rake to push through wall and into 5 gallon buckets on inside. Either that or recruit 1/2 dozen friends and bucket it all.I've got two blocks removed from the concrete block foundation that should allow a chute through and a small 16" x 6" high vent that can be removed. Tough part is the house is on a small sloped lot so the closest a truck could get is about 10-12' from that side of the house. The street I live on is tiny and has one lane of parking with just enough space for a truck to pass, but not very bust and I know all my neighbors.
Buckets, unfortunately, may be a good idea. I figure, hauled out like 23 yards of soil out of that hole with 5 gal buckets and wheelbarrow, what's a few more in concrete!
Probably only 4' feet of foundation wall and then the footing.Wouldn't you rather dug it out more do you can stand up? Or, is that not possible/feasible?
I know what you're saying, but it's about the most labor intensive way for him to get a small, maybe 6' by 23' hallway at "full height", but it's still not the same as above ground space value...........I'm not a concrete guy. But I'm familiar with digging out a basement and pouring concrete to turn into living space. That's very popular with the older south Philly home. Very labor intensive. But, those that live in South Philly, love south Philly. Me...not so much.
My buddy lives there and had it done.
The reason I'm doing this right now is because I'm rebuilding my entire structural floor so I've cut out the floors above this crawl. It's total luxury compared to what you're imagining. But this past winter I was under that floor digging to pour footing and pier to support my new LVL girder. That sucked.jb4211 said:Wouldn't you rather dug it out more do you can stand up? Or, is that not possible/feasible?
Most guys, myself included, have switch to just fiber around here.You can order a mix from your supplier that has a fiber in it that takes the place of wire in my area. Its not your traditional fiber and when you put the pencil to it you will break even on the wire vs fiber. I dont think its a steel fiber but its a polly.
