Mike,
While not as heavy duty, I like this for flush cutting:
You are able to angle it a bit better if you really need to get something flush. The problem with the Crane is you cannot get closer than the shroud allows.
I'll admit, the Crane is vastly superior if you need to do a lot of cutting. However, the Bosch is nice, the replacement blades aren't too expensive and you can flip the blade to get into both right and left situations.
Just an alternative idea if you don't need heavy duty.
