How does one prevent the surface of concrete from popping off? I think that's called Spaulding?
Also, how do you stop the cracks? Is it more gravel base?
Also, if you have a 6" pad would doubling the gravel, provide more support, or would it be cost effective structurally better to go with 8"?
What's the weight limit that a 6" slab vs an 8" slab can hold in regards to vehicle weight?
Does more rebar make it stronger?
Don't worry I have more. :whistling
