Chemical strip, will work the fastest definitely. Sanding glue sucks, it gums up the pads/sheets/discs. Use a paste type stripper, brush it on the damaged areas, go around the whole place, come back to where you started, and scrape or use a putty knife. Wipe it clean, maybe a quick hit with a sanding block....good to go.
