1 - 20 of 26 Posts
WHAT KIND OF DRILL BITS, OR TOOL OR MACHINE YOU WILL USE TO CORE 7/8 HOLE 8" DEEP IN CONCRETE, TROUGH TWO OR THREE #5 OR 6REBARS, HILTI WET DIAMOND BLADE IS OUT OF QUESTION, BURN OUT IN FIVES MINUTE DIDN'T DRILL NOTHING. ANY SUGESTION PLEASE, IT IS VERY IMPORTANT, YOU CAN EMAIL ME TO IF YOU WISH AT.
[email protected]
Have Trowel, Do travel
I have had no problem drilling with Hilti's core bits.
I use the ones specifically for wet cutting thru rebar.
I have used others as well, Its important to use the right diamond cores for the job.
It's more important knowing what your doing. I have done over 500 holes thru reinforced concrete with various machines, take it easy and take it slow,
I hope your using the base for drilling .
by burning, or ruining the bit tells me your doing something wrong.
Oh, and welcome
Contractor of the Month
I'd bet a coffee that a 7/8" rebar cutter will go through rebar faster than a core bit.
Just drill until you hit bar, then toss in the cutter.
Discussion Starter · #12 ·
We use all right excluding rebar cutter we will try tomorrow, problem is, i have to core or drill 2000 same holes and if i reach only 50% steel will be very hard, well thank you for yours inputs, will let you know what happen tomorrow
branko tomas
Project Superintendent
branko tomas
2000 Holes? I repeat my advice with more emphasis: Call Your Local Coring and Cutting Contractor! Then the only thing you will need is a Sharpie to lay out the locations. ;)
branko tomas
Well, we are talking about concrete and rebar right? These materials are used because they are durable, which by definition means they are not easy to put holes in.
1 - 20 of 26 Posts
