Hello all!
Ive decided to upgrade to a propress tool setup for primarily copper pipe installs. The fittings are a fortune which got me to thinking about bending copper pipe whenever possible.
I bend emt all the time for electrical work, but Ive never done it for plumbing. Ive seen a few videos about it, and Ive looked at alot of copper tube benders online that range from just a few bucks to several hundreds of dollars to even 1000+ if you go with a fancy ridgid hydrolic model.
Would love some advice from people who have experience bending copper pipes for water supply lines. I dont see myself bending anything over 3/4" and I think 90% of it will be bending 1/2" copper pipes.
Questions I have are:
- Is there a down side to bending copper pipes for water supply lines?
- I see alot of videos of HVAC guys bending pipes but not many plumbers, is that for a good reason?
- Is there an affordable tool someone can recommend to bend copper pipes? Are there cheapy crappy ones that will only frustrate me and ruin my work that I should stay away from?
- Is there a thickness that I should avoid using? I typically like using type L for residential installs whenever possible.
