Well I have posted befoe regarding my continued problems with my 2-ton 10 Seer Goodman Heat Pump. It now appears that the problem is the unit is is EXACTLY sized for the square footage we have according to code byt logically it does not work.
There is absolutely ZERO leway with the size to square footage ratio and whenever it gets over 89 degrees our unit never shuts off and runs for hours on end. The Thermostat gets to the set point I have it at but it will never shut off. As you can imagine this is taking a toll on our power bills.
It looks like I will have to change out the unit for a 2.5 ton 12 seer unit. Can anyone give me a ballpark price on these things?? It sounds like I need the outside part and a new Air Handler as well.
