1 - 12 of 12 Posts
I work as an estimator for a GC and always run into something new that is not black and white to me which keeps my learning juice's flowing for the next project. Per the note on the drawings, we have to install steel to hold up a glass enclosure so I have the metal and glass covered. Now its the anchor bolts I am skeptical about who can help Furnish and Install that???.
I did a sitewalk and its an existing concrete deck and the job is union is so who does what is important.
Do I need to a hire a concrete sub to cut open each opening and let the structural sub insert his anchor bolts and base plates and then the concrete sub infills them in at each location. No other concrete scope that is shown in this project I can think or so is a concrete sub the right sub for this work or is there another way?
Thank you,
510662
GC
Thank you,
The detail seems incomplete to me. Is there a detail for the concrete under this, or is it going into an existing slab?
Contractor
Why wouldn’t the glass enclosure installer just drill and epoxy in the anchors?
Ive never seen anchor bolts filled in with concrete.
He said it's a Union project.
Probably need an electrician to plug in the drill, a vacuum operator for dust collection, a certified anchor placer, a mechanic to tighten the bolts and a teamster to unload and load the truck. :ROFLMAO:
The detail calls for a 3x3” steel column with a 3/8” base plate welded on the end, drilled for anchor bolts. Most storefront subs will exclude all structural steel, they limit their scope to their aluminum extrusions and the glazing. The gc will need to get a steel fabricator to submit shop drawings for approval, then fabricate the column and baseplate assembly, and deliver it to the site. Once the column is in place, the storefront sub will verify the dimension, then schedule his crew. I’m thinking the OP needs to contact the iron workers local to see about getting the column installed.
GC/carpenter
GC/Carpenter
That's some funny **** right there!
Mike.
___
All of it, a simple job for any carp. But — union is union. When I was younger in the carp union, we did the whole show. A lot of cake under table & all kinds of crooked chit & a different ball of wax then. Some hellacious parties too
Mike
Goin' Down in Flames....
Highwayman
OK
Wasnt sure how that tube was getting attached
In that case, like Eddie said, I’d hetva quote from a fab shop.
Never done union work as a gc, did this from beginning to many times, You GC should tell you, otherwise he has no business doing this job. By the way, the plate seems thin in relation to the size of the bolts and the post.
1 - 12 of 12 Posts
