U
Unregistered
·Guest
do i need a special license to lay computer wires on a home before built?
thank you in advanced
froy
froy
Regardless of who does it, it will no doubt require inspection for code compliance. If you don't know what you're doing, hire someone who does. If a networking specialist isn't the one who actually does the install, make sure you at least have them specify, to you, the exact type of materials that are to be installed. Then make sure to convey that information to the installer in writing and well in advance of the work.Unregistered said:do i need a special license to lay computer wires on a home before built?
Teetorbilt said:Unregistered, No one knows where you are from and apparently the laws are different depending on where you are. I would suggest a trip down to your local building dept. and they can tell you for sure.
