I read the post about the compressor and I am having a similar problem, I bought a sears compressor 115V 15 amp it says on the unit. I plugged it into an outlet and it trips the breaker automatically. I plugged it into an 20 amp circuit that I know nothing else is hooked to and it automatically trips the breaker as soon as the compressor starts up. I understand the problem that initial fist second or two it probably draws 25 to 30 amps then it will only draw 15 amps. The instructions say use a time delay fuse, I have not had anything done to it but If I have a 20 amp circuit the a 15 amp time delay fuse when it starts up wouldnt the breaker still trip? What is the proper way to set this up? do they make time delay breakers?
