1 - 20 of 25 Posts
Contractor
Hey guys,
I'm about to bid on a job with 40 commercial grade doors all with panic bars attached. I've installed thousands of doors through my hotel remodeling career but I've only done a few panic bars and that was a while back. I'm wondering approximately how long I should allow to install one standard 3-0 commercial mdf door and attach a panic bar? No need to delve into a discussion about experience, know-how, knowledge, efficiency etc, I'm just looking for an approximation from experience from anyone who's done a lot of these before. Thanks!
A 36" slab will not require cutting the bar, but a smaller door will require cutting, not a big job, but it adds time, Also, you need to file the cuts clean, and you should run a magnet around the cut to remove filings that could end up in the latch causing binding.
25 minutes is more than enough time if it is just a panic bar.
griz said:
No access from exterior? Door closer/kick plate? Bottom sweep/threshold? Exterior stop? Mortise strike & cup?
Drilling and tapping holes?
Top and/or bottom latches?
Handles?
Oh, and no matter what, the ABSOLUTE first thing you do is...
READ. THE. DIRECTIONS.
Seriously.
No door will have an exit device without a closer, so I would look into that also.
Add an other 15-20 min. For door closers.
Kick plates suck. I hate getting on the floor. I can't charge what I want to for those.
Most doors with panics will have kick plates.
Good luck.
Contractor
Discussion Starter · #14 ·
Thanks for all the responses! I'll have to put closers, kick-plates, panic bars, peep holes, smoke seals, bumpers, etc...I ended up bidding the job for about 30% more than I thought it would take...I didn't want the job to badly anyway. They didn't even hesitate on the price, probably could have added another 50% Oh well, start the job tomorrow...43 3-0 fire-rated doors to hang and 43 to take down and dispose of. Gonna eat my wheaties tomorrow morning :-D
Contractor
Discussion Starter · #16 ·
Thanks again for all the responses. I've hung all the doors and hardware except for the panic bars. For anyone in the future who runs into this type of job I'd like to post my thoughts.
The doors went up as planned...10 min max to hang the door from laying on the floor to swinging. What got me on this job was taking the old doors down and moving the new ones into place... that took longer than hanging the doors themselves.
The first closer took me over an hour. The second took me 20 min. The third and 40 after that took less than 10 min per. Except for the jambs with poured in place jambs... we had to drill the metal then drill the Concrete then install the closer..
The one thing I didn't anticipate is that the panic bars are connected to safe locks... hotel key card locks. They don't come in for another week and we can't install panic bars until they come in. Hoping we don't run into any issues with those....
Project Superintendent
The key cards are usuallly a pain. Be prepared. But it all has to do with the learning curve. If you have a big bunch to do, you will figure out a system pretty quick.
Contractor of the Month
Probably surface strikes, the easiest thing you will ever install.
Contractor
Discussion Starter · #19 ·
Can the safe locks be installed after the panic bars? That is what the hotel intended but I refused to drill holes in a brand new fire rated stain grade door without having the other side of the lock on site.. these are double doors to so the other side has to match the same height..
Yeah certainly, but find out what model they are using so you can back set it the correct distance...because it's different if it's surface vs recessed.
1 - 20 of 25 Posts
