1 - 14 of 14 Posts
Helo all. I am a deck builder in upstate NY.Very hot right now. I was wondering what to use to clean circular saw blades after cutting several decks worth of PT lumber. Is it even worth the time or do I just toss them and buy new ones? The teeth don't get chipped or anything, just gummed up with sap. If anyone has ideas or thoughts I would love to hear them. Thanks in advance.
Electrical Contractor
Hey neighbor. I have always heard oven cleaner works well. Never tried it though.
IMO, for the low cost (<$10) of a decent 7.25" framing blade it would not be terrible to just toss it after each job if it's that bad. I assume this much can be built into the price of the job.;)
I forgot about that, Speedy, - - but you're right, - - I've heard about the oven cleaner for it for years, - - supposed to work really good, - - nasty stuff though, huh?
I kind of agree with you in one sense, - - 'if' it's a cheap blade, - - but sometimes it's good to clean it as you're using it. I'm usually using 40 tooth blades in my sidewinder, - - they cost more, - - but get better cuts and more bang for the buck over-all.
DGR,IABD
At the risk of sounding ignorant (too late maybe), I have to ask. Does the buildup occurs on circular saw blades when sawing certain types and species of wood affect the performance of the saw? or is it just a housekeeping issue?
Yes, it affects the performance exponentially, - - when the blade 'gums', - - it effectively dulls, - - meaning less 'chiseling' action in the cutting process, - - and therefore more 'friction' action, - - leading to more heat, - - causing blade expansion, - - compounded by 'wobble', - - then even more friction, - - causing a 'burning' action, - - leading to more dulling, - - etc., etc.
Discussion Starter · #10 ·
I really started a dicussion here. I just don't like waste and figured with a little work I could save the blades. The teeth really aren't shot( not chipped or dull) just gummed up. Maybe I should ask on the deck forum and see what other guys cutting PT do. Probably not worry as much as me :cheesygri
Dad always had a small pail of kerosene or mineral spirts that we put the blades in overnight.
I still build in the cost of new blades to a job. You can resurrect a few old ones and lose some brand new ones.
Deck Designer/Builder
I've seen spray cans of "saw blade cleaners" in big box stores up here - it may be the one Tom is talking about, can't remember.
Also, one thing I always do is have seperate blades for the PT and cedar and switch them after the framing is done.
1 - 14 of 14 Posts
