EIFS is one of those substrates that most cleaning contractors don't like to tackle. It can be difficult to clean, and easy to damage. The trick is let the detergents do the work. Use only low pressure, do not get to close, and try to stay away from using brushes on it. Perhaps a good high concentrate truck wash soap, would be your best bet. Try to stay away from high caustic or butyl based cleaners, as they can do damage to the elastomeric coatings. If they are required make sure to dilute them properly. Many people use bleaches on them. Be careful with bleaches they can fade the color, and if left on for to long they can leave a chalky residue. Bleaches work very well as a follow up quick app. to remove any green, that the soaps could not remove. But
Britenol HD is fairly inexpense and does an excellent job removing mildew stains, with up to 5 times longer lasting results.
Cleansol BC from
EaCo Chem works well at removing the carbon stains from the EIFS. If you are dealing with more of a specialty stain, such as metal oxide stains, water stains, leaching, clay, and so on, their product
SafeRestore and sometimes
Britenol HD can be most effective. If they are particularly difficult stains, a 1 2 step may be required (Acid then Alkaline, then rinse) Just remember never mix bleaches with acids (saferestore and britenol are acids)
ShoreBest also makes good EIFS cleaners as well.
Prosoco makes EIFS Clean N Prep, but isn't really that great. I have removed many stains from EIFS that several specialty contractors said were impossible to remove. They laughed at me and told me I didn't know what I was doin, they had come up against it to many times and nothing had ever worked. They stopped laughing when it looked like new when we left. That type of thing has happened on several different jobs. I would once again suggest
www.eacochem.com
Gutter Clean & Power Wash
Hickory NC
