Thanks Dave!very cool great series,i don't get to work with lead looks like a great material to work with
the welding lead video was interesting too
Actually, it is a better look than the 5 or 6 pieces one usually sees on a chimney.I have never seen it done quite that way before. I don't think I like the look of that.
I can still buy lead at several sheet metal and roofing supply houses.Dave,
Are there any restrictions on using lead flashing there?
Lead has been great to work with,easy to cut,bend,mold.
Too bad its use is probably going to be banned with the new EPA regs.here.
if you can do the identical task in half or 1/3 the time, doing a "really nice job" with identical quality, simply by saving steps and thinking through the task. you would make double or triple the money in the same amount of time. Capish?Losing money?
How do you lose money taking your timg and doing it the right way?
If one is using lead to counter flash a chimney, I am pretty sure you charged enough to make it a really nice job.
I will not climb on a roof and counter flash a chimeny for chump change.
We have no trouble getting roll lead around hear. For counter flashing we normally use lead coating copper. This seems to be getting harder to get. From what I hear the largest manufacturer of this product stopped making it a few years ago.Dave,
Welding lead is hard hard hard. I've soldered copper and soldered galvanized but lead to lead is a b!tch!
