Anybody got anything good or bad to say about the cheap tile Lowes has on sale right now for .79 per sq ft. The only color my store carries is Texas Beige and it doesn't look half bad.
Keep in mind, like all building materials, it's cheaper for a reason. We don't have Lowes here in Canada but I see the same thing, especially in the spring, at HD. I'm no tile expert but there's a reason that some ceramic tiles cost more than others.Tscarborough said:What exactly do you mean by "better"? It is ceramic, is is square and it lays on the floor. If Lowes wants to give it away instead of charging 50% markup, why does that make it "worse"?
Just to add to Mike's post...Mike Finley said:Ugh, I hate cheap tile, and cheap to me is anything less than $3.00 a square foot wholesale pricing.
.79 cent tile even with 50% mark-up is still $1.18 tile, I would shudder at the thought of having to work with that stuff and even worse having to right the whole job off as a waste of time because of how generic and bland it is going to turn out.
Why do I hate cheap tile - let me count the ways...
Looks cheap, ugly screen printed patterns that look like the dot pattern of a newspaper, or bland washed out generic nothingness...
Having to do cuts over and over again because as always in the last 10 seconds of a complicated cut of 5 minutes the crap is going to chip, split or crack on you.
Bad consistancy of colors from box to box even in the same die lot.
Bad consistancy of sizes.
All those dam edge chips that you miss untill the next day when you are grouting it.
I could go on and on, but the bottom line is as stated, you always get what you pay for.
WOw. Are you really sure about that?Tscarborough said:I will freely admit that I don't know much, but I will also submit that it is a floor tile, and that other than bragging rights, a cheap ass ceramic tile will perform as well as an expensive one for 99% of all applications.
That's another good point about that cheap fired ceramic tile.snapper21 said:If you get that tile be sure you don't drop anything solid on it, and choose a random pattern or your grout lines will differ in width if you take the time to keep them in line. Don't think about using spacers if you have a larger area than a closet.
My brother didn't listen to me and went cheapo. His kid dropped something on it, cracked off a corner and the next day he was at the doggie emergency room because his dalmation slit it's paw wide open on it.
What you are seeing is the amplification of the problems with cheap tile. The larger the tile the more pronounced the problems become. What might be a minor or un-noticible issue with a 4x4 tile now becomes very blatant with an 18x18 version of it.joasis said:We have done large and small jobs with both cheap tile and high dollar stuff...I asked my guy who does tile (very talented) what he thought, and as a setter, his opinion wasn't so much about the cheap vs. expensive as the flatness of the tile. We have yet to see many problems with the cheaper tile, but we have had hell with high dollar 18 X 18 tile that had a slight cup to it.
Since I am building 2 spec homes now that we will cut the floor with a concrete saw for grout lines and stain the concrete, I hope to avoid tile for awhile.
