1 - 20 of 33 Posts
I'm currently in the process of building a house. I was issued permits based on one design, and after permit was issued, the client made substantial revisions to the plan which require almost completely new structural drawings. The original engineer I hired to the do job is refusing to revise the drawings as he states that we have to build according to permit set.
Has anyone ever got two structural engineers involved in a project? I have one on standby to issue revised drawings.
Remodel
Around here, I've had to revise structural plans while under permit. I just had to submit the revised plans.
Maybe what you are talking about would be a big deal requiring repermiting. Tough to say, but plan revisiins aren't uncommon
Discussion Starter #3
It's not uncommon at all, which is what I don't get.
The changes are extremely different, footprint remains the same, building height is the same, top floor is just wider so it will change load points etc.
Remodel
BTW, you do have to build to the permit set, but that doesn't mean it has to be the original set. Your permitting official can answer whether a revised set would be acceptable or a whole new permit would be needed.
Get 2 engineers in this, and one us likely to be a problem. If you build to revised from the second engineer and the permit is using the original set, you will be busted at inspection. The engineer can't have you build it with their name in it.
Discussion Starter #6
Yeah,
I would be running the new plan by the inspector prior to construction.
Remodel
Top floor being wider could trigger more than just engineering. Egress, window area, and so on. If the building officials are good with having a revised plan set under the existing permit and your engineer won't do it, go with the other engineer.
It sounds like the guy thinks something shady may be going on.
Things get real messy bringing a second design professional in. Around here you have an engineer or architect of record who creates the plans and submits for permits.
I've run into these deals with major design changes midway into a project. It required a bunch of re-drawing and re-submitting to the authorities, but we never switched designers, just had our present designer make the revisions and pay him accordingly.
If you bring in a second designer and make a bunch of changes, I could see the first getting pissed off and wanting to walk away invalidating the permits. The drawings typically remain the property of that designer also, so somebody else can't legally modify his work. You would likely have to create a complete new set of plans and resubmit for permits with the second designer.
Unless the original designer is a problem, I think it would be foolish and more costly bringing in a second guy.
Discussion Starter #9 (Edited)
Heres the difference, this picture shows the top floor being in from the exterior walls of the floor below (main)
We want it so the top floor follows the same exterior footprint of the main floor. It would require adding about 7 feet to the top floor width.
GC/carpenter
I don't think the second guy can make changes to to the first guys without permission. There's copyright laws in place.
Mike.
_______________
GC/carpenter
That can change the whole dynamic of everything designed below it from the footings up.
Mike.
_______________
Discussion Starter #12
Mike.
_______________
For sure,
I know the way the footings are designed currently are big enough to take the load of a complete top floor, but still, I need it engineered.
I'll have to have a chat with him on Monday, worse come to worse I'll get it re-engineered from scratch.
In general, building permits serve two goals of the local government, It gets all large improvements to Real Estate Property ON THE TAX ROLLS, and forces builders to conform to minimum standards of construction....
Thus you are trying "sneak" a VERY large footage increase with out PAYING your permit fees that are based on value of building.
Will the note holder allow this criminal conspiracy to occur on it's property?
Didn't YOU charge for this Massive change order and INCREASE in materials and labor, Plus LOST TIME?
Why wouldn't an Engineer be required to engineer a a structure "that has MORE than 5 % change in loads? 7" Maybe, 7 Feet that is a NEW Plan silly man.:jester:
Haven't you PAID the 1st S.E.? Why NOT use him as least cost person to change plans with least added materials and RETURNED steel......
Changes are common, I smell a cheapskate 'Rat' that doesn't want to pay for Work performed, But Unused by a indecisive customer/ GC....
I can't see this as even a serious question by an experienced competent builder, I'm thinking, New Guy or a morally bent actor.....
Your Next building might require you to find a SE that hasn't heard about this home.....
I'm concerned that NO one has told you how far wrong you are within your local circle of contacts, Do you punish "bad news" bearers? Or just garden variety ignorance/inexperience?
Discussion Starter #14
Why wouldn't an Engineer be required to engineer a a structure "that has MORE than 5 % change in loads? 7" Maybe, 7 Feet that is a NEW Plan silly man.<img src="http://img.contractortalk.com/smilies/jester.gif" border="0" alt="" title="Jester" class="inlineimg" />
Relax brother.
Pretty good reception for Trump in Maine
:laughing: haven't seen 4th gen around in a while
Sent from my SM-G930V using Tapatalk
Why is the original guy refusing to redo it? Does he think you are not going to pay him, or does he think by redoing his work, he may think you may not want to pay his standard rate? I don't get it.
Custom
That seems to be the relevant question here... if you're willing to pay for the revisions, there should be no reason for him not to revise it... it would literally be like a new client, except half his work is already done...
Goin' Down in Flames....
Highwayman
Relax brother.
Everyone here pretty much ignores "fouth". :blink:
Lot of hot air, not much content. :rolleyes:
I'm not understanding why the original engineer or designer wouldn't revise it. My designers and engineers will redraw anything as long I'm willing to pay them to redo it. Easiest money ever. :whistling
The Hard Rock Condo in New Orleans got to make changes in the as built plan with out getting stamped "new" Permits......
Permit fraud = TAX Fraud IMHO :sad:
Changes in build that don't add to final VALUE don't need permit changes IF THEY MEET THE CODE(s)
e.g. Does the 7 foot wider 2cd story push the roof peak over the common 35' residential limit in total height?........shading lawyer/ neighbors award winning garden.....
A lot of facts blowing in this Santa Anna....
New plans, new permit, + new Engineering review/Stamp = ADDED PROFITS in any fair contract between builder and Owner()s)......More Time = More $$$$$ How can this even be a post?
1 - 20 of 33 Posts
