The tile forum on DIYChatroom isn't bad. Good advice from at least one C.T. member is to be had there.Yes you do--wood moves a lot---You may wish to check out DIY Chatroom - DIY Home Improvement Forum
This is a sister site aimed at walking novices through the basic steps involved in home improvements.
You're an electrician - break out that gas powered sawzall with the 30" blade and the jackhammer. That wood doesn't stand a chance!I'm wanting to install ceramic tile on the walls and the walls are cedar . I would like to know if I need to replace the cedar with cement board? Electrician Performing the honey do list Ugh. It would save alot of time if I could tile on top of the cedar.
