1 - 20 of 23 Posts
· Project Manager HFH..
I would like to install a drywall ceiling in my garage but the existing four rafters are in terrible shape. It is an old home built in the 40's with a detached garage. In order for the ceiling to go up, I need to install joists. Any suggestions as to how I can install the joists (thinking 2x8's 16" OC). I could run them perpendicular to the roof rafters, which would make them easier to install, but then the load would rest on my garage door header. Do you think that would make my header sag in the long run? What do you recommend I do?
Call a contractor.....Simple.
· improving homes
So you never responded to weather you're a DIY'er or a painting contractor? Pretty sure I know the answer to that. If you called me for an estimate I would give you an estimate, a price to do the job you want done. I will not give a detailed list(instructions) of the process of what how I'm going to give you what you want. I will give some small details of what is involved to justify my price but would not tell you how to do it.
Why don't you go to www.diychatroom.com and ask your question there. They have some knowledgable people that will be more than happy to answer your questions. Good Luck. My advice=tear the whole roof off and install trusses and new roof and then drywall.
· Jeff
If it was me id just span some fur strips from side to side to hang the drywall on to eliminate some of the weight. Just scab em together in the middle somewhere, if they span a long ways you might wanna get some tie wire and hang em off the rafters.
· Dufus Extrodinaire
This is good "solid" advise. Many of the home builders here do it this way all day long. Light weight and saves more trees :clap:
· Grand Rapids Remodeling
I bet you would.....Contractors always want to do more than is required so they can charge more.
That statement will be a great way to make friends here Mr. painter. When you finally make it to the correct forum as was kindly suggested please by all means feel free to insult the diy community also. When your 1940's garage is sagging and your drywall is falling down around your ears feel free to hire a high priced contractor to come and laugh in your face.
:jester:
1 - 20 of 23 Posts
