1 - 20 of 61 Posts
Contractor of the Month
Drywalls fill me in here...I was on a site where the renovator (didn't seem like a very competent guy) was putting up sheetrock and ran a bead of alex caulking on every inside corner...no mud or tape.
I asked hi, why because I've never seen anyone do this and he claimed its "faster and looks better".
I have yet to see what the end result looks like but I'm still puzzled by it, is this common?
It will look good for a little while.
You should tell him you knew about a guy that also just caulked the flat joints. The rube will probably spend years trying to figure out how to do it.
Spin him up even more tell him you caulk the tile floors in the field too.
I run across caulk in the corners all the time, but that's plaster and a lot of guys figure it's easier to caulk then tape and mud the corners, but new sheetrock with no tape that is just wrong:rolleyes:
You may see that in remodeling occasionally but not all that often. But it's a standard way of fixing corner cracks in modulars and doublewides after being shipped from the factory. Many factories drop the pretextured roof on the house with a crane and finish it this way.
Project Manager
This seems to be a commercial thing in my area.
I have been on multiple jobs for two different commercial GC's, and all the drywall inside corners were caulked - no mud and tape.
I asked around and the most common answer was that it was faster.
Administrator
Sawdust follows Me Everywhere
Did they use fire caulk? If not it shouldn't pass code.
Sawdust Sweeper
In remodeling I will run a small bead of dynaflex 230 in the corner after mudding, taping and priming and just prior to texture.
I have done that (after tape). It makes a smooth corner for paint.
:whistling
:whistling
:whistling
OK... I did caulk-only just the lids on a job that was getting crown..once. It saved a lot of time, but just didn't feel right.
Working
Yep same here it is a comercial thing. Have seen it a several times but allways on comercial buildings.
1 - 20 of 61 Posts
