Rumford's footnote;but merely set down upon the hearth,
The Orton is a slanted backed firebox vrs. a straight, like Rumfords' first invention ''his prototype''.
The proto type was designed as a remedy installed into existing, thick front walled fireplaces, hence the straight backs and thicker front breast which demand rounding or risk smoke!
To function well the throat of a slant needs to be 8 or 9'' behind the face,. add a 4'' throat and a 6'' slant or so and you'll have a 19 to 20'' deep box.
Rumford did give some hint to lessening the acuteness of the side walls so as to receive longer rear logs.This is a nice option on a slant [ESPECIALLY FOR OUTSIDE] because when new logs get added they go onto the rear so the smoke gets carried up easier,...a handy trick which keeps the smokier logs at the back and up along the slanted wall and rule of thumb for all fps.
I feel the 180 chords or so I've burned the past 30 years taught me that much.
Any idea of a heat loss do to widening the back a bit to accept a longer log is made moot due to extra heat that radiates from the slanted rear wall.
Orton suggests a back that is between 2 and 3 times smaller the front width but try and keep closer to 3. Mine is 50'' at front and 36''at back and 20'' deep. At this angle the sides still can perpendicular-ly radiate heat out into the room without hitting the opposite wall,so no loss is had what so ever, in fact the wide angle is increased! As to depth I could easily do with 18'' but years back when cooking was common place in the FP it was handy.
Buckley plays games with his fire box plans which he affixes the name True Rumford to. He shows fireboxes with true Rumford depths on one side of the F.P. jamb, then on the other he adds a face of up to 5'' which is more the Orton without a slant, but certainly not exactly a true prototype.
If you look at his 6, 7, and 8' FP plans he adds double steel lintels and a cast iron damper [lips included] and a slant the top to accomplish some added depth.There is no other bigger smoke causing error than continuing to enlarge the depth of the breast to accomplish the above, hence the need for ti pi fires.
As to placing top dampers on a straight backed Rumford fireplace I don't
think they will hurt because the dampers can't really be choked to save heat due to the fact the throats do not run the entire openings length, and the breasts are thick to boot!
But on a Orton slant, the full length damper is needed when choked small.
Any choking at the top will be minimal and cause smoke.They can be draft inhibiting with different wind behaviors and turbulent in slow days.
''Smoke on a rope" is what they are to me.
Perhaps when I do my 2'' choked damper video some will understand the significance of a thin long opening along a true full length throat.
I'm pondering getting Lilly my 2 year old grand daughter, to help..lol ?
Here are a couple links to straight back Rumford situtaions. One is a reply to me about the throat kit and the other is a straight burning
with smoke stained front and if you look close it's smoking slightly which is the most aggravating eddy type. Both these problems can be location caused or short chimneys I don't know.
http://www.youtube.com/watch?v=ZTQ6jdQHJN8 smoke on face
a fire in a Rumford note his reply.
http://www.youtube.com/watch?v=TnDu9Wf86Vc
This is Rumford's footnote referring to his experimenting on slants.I've read this a million time and just the last time I focused on the part where he mentions it can be sat on the hearth and separate from the chimney and used in new construction!
I immediately thought about him hiring a potter and the possibility of a
entire unitized ceramic slanted firebox and throat.One that just sat there and could be moved to any?
Any Thoughts? Could he have been aiming after the Franklin stove but with unitized masonry?....I'm positive Ben had the stove for 45 years already.
FOOTNOTE;
[353]
Of Chimney Fire-places. When the wall of the chimney in front, measured from the upper part of the breast of the chimney to the front of the mantle, is very thin, it may happen, and especially in chimneys designed for burning wood upon the hearth, or upon dogs, that the depth of the chimney, determining according to the directions here given, may be too small.
Thus, for example, supposing the wall of the chimney in front, from the upper part of the breast of the chimney to the front of the mantle, to be only 4 inches (which is sometimes the case, particularly in rooms situated near the top of a house), in this case, if we take 4 inches for the width of the throat, this will give 8 inches only for the depth of the fireplace, which would be too little, even were coals to be burned instead of wood. - In this case I should increase the depth of the fireplace at the hearth to 12 or 13 inches, and should build the back perpendicular to the height of the top of the burning fuel (whether it be wood burned upon the hearth, or coals in a grate), and then, sloping the back by a gentle inclination forward, bring it to its proper place, that is to say, perpendicularly under the back part of the throat of the chimney. This slope (which will bring the back forward 4 or 5 inches, or just as much as the depth of the fireplace is increased), though it ought not to be too abrupt, yet it ought to be quite finished at the height of eight or ten inches above the fire, otherwise it may perhaps cause the chimney to smoke; but when it is very near the fire, the heat of the fire will enable the current of rising smoke to over-
A A 3
[354]
Of Chimney Fire-places. come the obstacle which this slope will oppose to its ascent, which it could not do so easily were the slope situated at a greater distance from the burning fuel*.
Having been obliged to carry backward the fireplace in the manner here described, in order to accommodate it to a chimney whose walls in front were remarkably thin, I was surprised to find, upon lighting the fire, that it appeared to give out more heat into the room than any fireplace I had ever constructed. This effect was quite unexpected; but the cause of it was too obvious not to be immediately discovered. The flame rising from the fire broke against the part of the back which sloped forward over the fire, and this part of the back being soon very much heated, and in consequence of its being very hot, (and when the fire burned bright it was frequently quite red-hot,) it threw off into the room a great deal of radiant heat. It is not possible that this oblique surface (the slope of the back of the fireplace) could have been heated red-hot merely by the radiant heat projected by the burning fuel; for other parts of the fireplace nearer the fire, and better situated for receiving radiant heat, were never found to be so much heated; and hence it appears that the combined heat in the current of smoke and hot vapour which rises from an open fire may be, at least in part, stopped in its passage up the chimney, changed into radiant heat, and afterwards thrown into the room. This opens a new and very interesting field for experiment, and bids fair to lead to important improvements in the construction of fireplaces. I have of late been much engaged in these investigations, and am now actually employed daily in making a variety of experiments with grates and fireplaces, upon different constructions, in the room I inhabit in the Royal Hotel in Pall Mall; and Mr. Hopkins, of Greek Street, Soho, Ironmonger to his Majesty, and Mrs. Hempel, at her Pottery at Chelsea, are both at work in their different lines of business, under my direction, in the construction of fireplaces upon a principle entirely new, and which, I flatter myself, will be found to be not only elegant and convenient, but very economical. But as I mean soon to publish a particular account of these fireplaces, with drawings and ample directions for constructing them, I shall not enlarge further on the subject in this place. It may, however, not be amiss just to mention here, that these new invented fireplaces not being fixed to the walls of the chimney, but merely set down upon the hearth, may be used in any open chimney; and that chimneys altered or constructed on the principles here recommended are particularly well adapted for receiving them
