1 - 17 of 17 Posts
Contractor of the Month
For the first time I used cast iron Lennox blades I purchased sometime ago. I had a cast pipe I had to cut in an awkward place where the grinder would not fit; instead of renting one of those chain splitters I opted to use the sawzall.
Surprisingly it cut clean and straight but better pack a lunch because they are slow! The blade didn't suffer all that much damage but I don't think I will be tossing out the grinder for the sawzall anytime soon.:thumbsup:
How does the blade hold up? Port-a-band would not have fit into this corner.
I cut the pipe into 4 foot sections with my 4.5" grinder and a cheap 3 dollar cut-off wheel and it cut through it like butter. I had hoped the 12 dollar saw-zall blade would have went a little faster. The sawzall is kinda of a last resort to all cutting jobs saw, I can't live without them but I really don't like em.
Sawzall is one of the most useful tools ever invented. Wide variety of blades to choose from. I once had to cut a section out of an existing steel beam using the sawzall. Beam was very thick and 12 inches tall. One of the cuts had to be on a 45 degree angle. It was one of those deals where the grinder woulda probably caught the house on fire and the partner saw couldn't reach it.
It is for sure, but for me its sort of a jack-of-all-trades master of none. I particularly dislike them because they vibrate so much and are very fatiguing to use.
For years I said I would replace my old DeWalt once it bit the dust but it just keeps taking all the abuse I can throw at it.
The Grand Wazoo
The Porta Band blade?
Buy good ones and use the speed control setting on the saw properly and you'll get over a hundred cuts on cast iron pipe with it easily.
Impressive, I've used others portabands for cutting conduit, threaded cores and strut but I never made the plunge myself. I use quite a bit of strut and tube steel but cut it with a 14" chop saw. The portaband was one of those saws that I couldn't justify since I already had the chop and the sawzall...not to mention I really don't have much room to carry around another bulky tool.
But I do like an excuse to buy more tools!
It's an expensive tool to use for metal as you burn through blades pretty quickly. I find that you usually get your money's worth in springing for the better quality blades. What you don't save in replacement blades, you'll save in time.
I use a sawzall almost exclusively for demo, as it's just not precise enough for much else.
I recently bought a Makita 15 amp AVT sawzall and it is amazing how good the anti-vibration technology works. It is so much better in that respect than any other sawzall I've tried.
The Grand Wazoo
I have A Porter Cable and the stand with vise for it to convert it into a drop style band saw, the vise holds the material square so that you get a square, burr free cut every time.
I agree with the criticism of the Sawzall in this application. Of course, there's "sawzalls" and there's Milwaukee Sawzall, and yes there is a difference. With that said, one of my plumbers showed me the best way of getting rid of cast iron pipe: bust it with a mini-sledge!
Construction Connoissuer
Would be my guess he was tieing back into it. :shifty: ?
Custom cabinetry
For strut and other such steel get a speed demon blade from diablo... oh yeah and get a face shield. Those blades are amazing, I have one in a 7 1/4 worm drive for cutting steel studs and its just like cutting wood... except for the hot pieces of metal flying wildly about :)
Those blades work well when you find a broken piece of cast under your slab. And the slab is below a cabinet that can't be moved because of a tile counter top.
Good thing this happened next to the fridge in my bar.
Da Grump
i tryed some milwaukee cast iron blades i bought a ferguson a while back.they worked a lot better than lennox blades,i wasreally suprised :thumbsup:
1 - 17 of 17 Posts
