Hey y'all, so I have a client with a full storm door that continuous blows open no matter what I do. I installed a heavy hydraulic closer on both the top and bottom and adjusted them so the door slams closed and latches. I also installed a chain. I came back today to finish up another project and found that after one night the door had ripped the bottom bracket from the wall, taking the wood with it. The top arm had bent. The bracket AND pin that held the chain to the door is also bent to the point where it is unsafe to keep up under tension. Other than charging her hourly for me to stand there and make sure it stays closed, what other ideas do you guys have?
Thank you!
Thank you!
