I need to bury 3/4 conduit in a concrete slab in an occupied gym approx 15 feet of.
2) 2nd App. need to remove about 1/4" of concrete on Approx 10. sq.ft of area.
Both are in occupied gyms, so dustless cutting and grinding is a must!
i have $1200 to spend on the vac alone.
Model 550H
http://www.cdclarue.com/cms/?p=36
Model PB-550 is a HEPA vacuum with a filter fractional efficiency rating of 98.00% @ .3 micron at a CFM flow rate up to 140. The PB-550 model comes standard with Pulse-Bac® Technology, our Cyclonic Debris Management System, a tank inspection window, HEPA H-13 filters and a 15’ x 1 ½” crush proof self locking vacuum hose.
Hiliti VC 20
https://www.hilti.com/holcom/page/module/product/prca_rangedetail.jsf?lang=en&nodeId=-11991
Rated voltage 120 V
Suction capacity 129 ft³ / min
Dust capacity 51 lb.
Water capacity 3.6 gallon (US)
A-weighted emission sound pressure level acc. EN 60745 71 dB (A)
Hose diameter 1.4 in
Hose length 16 ft
Max. vacuum pressure 3.2 lb/in²
Dimensions (LxWxH) 19.9 x 15 x 19.7 in
Makita
http://www.makitausa.com/en-us/Modules/Tools/ToolDetails.aspx?Name=VC4710
Powerful 12 AMP motor generates 135 CFM of suction power and 92" of water lift to take on the most challenging applications
Motor chamber constructed of quality sound-absorbing materials resulting in a quiet operating sound level of 59 dB(A)
Utilizes precision lightweight motor components and efficient air ducting to produce a vacuum weight of only 27 lbs.
Automatic Filter Cleaning System with blow-back feature is timed at set intervals to maintain filter performance for longer filter life
Rocker valve isolates reverse air flow through each filter separately to not interrupt suction
Onboard tool-activated outlet starts and stops vacuum with power tool usage
10 second delay after power tool shut off to clear hose of remaining debris
Soft start function for lower amp-draw at start-up
Integrated cord reel and hose brackets for operator convenience
Variable speed control dial for a variety of applications
Large, wide-set, urethane rear wheels create a lower center of gravity for better stability
Enlarged steel caster front wheels are engineered for easy movement over rough surfaces
Equipped with 24.6' cord and 16' anti-static hose, for better reach and suction performance
Removable accessory storage tray for optional accessories and parts
Quick-release latches for easy removal and disposal of collected materials from canister
Lower profile flat filter design maximizes the container volume and improves efficiency
ETL certified to ANSI 1017 standard for vacuums with onboard power outlet
Meets the EPA (RRP) rule for HEPA vacuums only with the optional main HEPA filter installed
Included: Efficient main nano filter set (captures 99.95% particles 2 microns and larger)
Optional: HEPA filter set is Certified to meet or exceed the efficiency standard (captures 99.97% of particulates .3 microns and larger) - certificate included
