Have one room that was added on years ago which is 3 steps higher than the rest of the house. Opened up the subfloor and there is room to lower the floor in order to make it level with rest of the house but by Code can I do it? The Footing for the "Added" room is slightly lower than existing house. If I pour a 4" slab on top of the footing is that OK? Then up from slab frame double stud wall up from there (against cinder blocks) and then existing wall up to ceiling rafters. House is in Massachusetts. Footing is about 2 ft below grade
