1 - 20 of 45 Posts
I did a resanding and varnishing 18 months ago, and the owner was very happy with the floor, I just received an email complaining about the white strip which appear on the floor. I put a polyuréthane varnish water base in 3 coats. could anybody help please.
http://i1162.photobucket.com/albums/q530/jmsign/photo4.jpg
french oak
im assuming your saying it wasn't like that 18 months ago when finished?
the only time i Have seen waterbase turn white is during apllication on high humidity situations.
now we should know if there a sealer used as a base coat?
a conversion varnish?
shellac?
Lacquer?
was the floor waxed after the fact?
these are all situations I can see white developing.
Last would be bleaching if the coat through sunlight..and in this particular grain pattern it accented a light portion of the board.
the finish appears to be intact and the marking isolated..
all hypothetical of course
It looks to me like that weird thing that sometimes happens to Jatoba where this white crap comes out of the vessels long after the finishing process is through. I don't know anything about French Oak, but I know with Jatoba, it's not considered a defect because there is no way to grade for it.
I'm confused,
If it is re-sanded, why are there huge "micro" bevels on the board edges.
Very light sanding?
With so much darkness in the seams, it looks like they wet mop the floors. One more vote for water damage.
Administrator
Sawdust follows Me Everywhere
If that particular board was more porous then the surrounding boards then the finish might of had holes/gaps/opens in it. The water can get in there and lift the finish from underneath.
Strip the one board and refinish it.
That is a spalted board---the spalting is softer than the surrounding wood and absorbs moisture faster than good boards.
Water born finishes are more brittle than the old oil finishes--so the finish broke bond---
Woodworkers frequently 'petrify' the punky wood with CA glue before finishing--
Livin the dream...
Thanks for the lesson Mike! I did a google search on spalted wood. I always wondered what caused those black lines in some pieces of wood. Turns out they are "zone lines" and are caused by fungus in "spalted" wood.
Learned something new. :thumbup:
Sure it is---scrape or sand off the finish---then saturate the soft areas with CA glue--(super glue) --when it's hardened,apply your finish---
You need to petrify that soft punky section so it is as hard as the good wood.
For a real lesson about splated wood--go to 'woodworking Talk' and browse through the 'forestry and milling' section----
To all of you wood lovers---track down small local mills---not only will you find great prices but you will find odd ball goods like spalted ,burls and unusual live edge goods.
1 - 20 of 45 Posts
