1 - 18 of 18 Posts
Most quarries, pits, etc. have a proctor/density on file. A lot of the base around here is anywhere from 1.2 to 1.4 tons per yd. depending on moisture content, etc. I
If a proctor isn't on file, grab a five gallon bucket, weigh it, figure the volume and do your own conversion........not as accurate maybe, but better than guessing.:thumbsup:
Anybody have a quick and easy formula to find out how many Tons in a CY....Tons in a SY?? Thanks a bunch
Just remember, a square yard is 1/3 of a cubic yard. That being the case:
For tons per CY take the depth (height) of the cubic yards in inches, squared, divided by 27, times .055.
For tons per SY take the width (short side) of the cubic yards in inches, squared, divided by 9, times .055.
Not quite. A square yard in a unit of area. A cubic yard is a unit of volume. You can't compare the two like you're doing. 9 cubic feet is 1/3 of a cubic yard.
Jerry,
I think/hope pipeguy realizes that cubic and square yards are completely different measures, and there is no conversion factor without knowing the X dimension
I hope he is just funning with the OP. With all that numerical mumbo jumbo, it sure seems that way ( fingers crossed)
We are about the same around here, 1.2 to 1.4 tons to C.Y.
Just call the pit and find out,
1 - 18 of 18 Posts
