This is for a relative who recently bought her grandpa's house. The Bryant is one of the 90% units and is probably less than 10 years old and looks to be in good shape.
Last month I was there I did a quick check on it and the furnace worked fine.
Recently the furnace began working intermittently. HVAC guy come out and says she needs a new furnace for $3500 because:
"The April Aire humidifier was installed wrong."
(Last month I told her the installation looked sloppy, but it wasn't hurting anything and I would look into it this spring.)
"The furnace fan motor bearings are shot." (Last month I told her they needed to be oiled but the impeller spun just fine.)
"The heat exchanger leaked water into the electrical compartment." This is apparently what was causing the intermittent operation. There were vague references about a part outside being installed wrong.
Without a parts diagram I don't know about this last one and thus I am asking your insight. I told her repairs should be way less than $3500 and a new furnace was not needed.
Another HVAC guy told her furnaces should be replaced every 6-7 years!
