1 - 8 of 8 Posts
What is the best way to remove brick from a wall to re-use it on the addition? I have a project that has a full brick wall that they want to remove a section about 22' wide and 8' tall for a new opening and would like to try and re-use the brick for the addition to make it blend in better as a wainscot of brick. I've never had to remove brick as most remodels have been with stucco, wood siding, or some other exterior. Any suggestions? Thanks.
· Super Moderator
Try an sds drill with a chisel attachment. Quicker than the other way and less wear and tear on your wrist. Start at top, work your way down. Just insert the chisel below each brick and the vibration causes them to raise up.
I've done this before with an air chisel (when I was younger working for someone else)... half the bricks broke when I was trying to get the mortar off. Hopefully you you don't need too many of them to put back in there.
· Sean
:eek:
you were using the wrong angle - as I recall it should be about a 15 to 25 degree angle, just like scraping a floor
Theres definitely a knack to getting them out without breaking them. It can be done but at the cost of some broken bricks for the learning curve.
You should use the cold chisel method as SLSTech described. There will be more control and less bats.:thumbsup:
1 - 8 of 8 Posts
