1 - 20 of 21 Posts
http://www.amazon.com/Bosch-CM8S-Si...TF8&qid=1398480695&sr=8-1&keywords=bosch+cm8s
I am in the market for a new saw, primarily for flooring and finishing work, something lightweight yet able to take some abuse. I have seen that this Bosch saw is new to the market and was wondering if any of you guys have tested it and or used it that might have some input on it.
If not, any of you tried the makita 7.5" slider ?
http://www.makita.ca/index2.php?event=tool&id=66&from=accessory
Thanks for all the help. :clap:
Without seeing it in person, I'd choose the Makita, if for no other reason than blade availability and cost.
as a matter of fact, 8.5" blades are way more common than 7.5"
and yes, I know you can use 7-1/4 blades, but not a true finish blade
Want to play a game?
A guy on another site bought the Makita and loves it. He also mentions the dust collection is awesome!
Considering weight alone the Makita is 28lbs and the Bosch is 37.
Don't forget about the hitachi as well. I have one we use for framing. The weight is a big factor for me to lug it out.
The new Hitachi 8-1/2" sliders are garbage.
I have two of the old Hitachi c8fb2 8-1/2" sliders, probably one of the best trim saws made.
The bosch only bevels one way, probably not that big a deal but something to keep in mind.
no different from any other 8-1/2 miter saw.
I've never needed a dual bevel in all the years I've used my Hitachi.
I think the Makita is single bevel also. But I hear what you are saying. I like a dual bevel saw. Just don't know if there is a manufacturer that makes a dual bevel under 10".
Paul
There are several true finish blades on the market. Forest, Tenyru, Bosch, Freud, and DeWalt all make one as well as CMT and Irwin. Check Amazon.
yes that's true, but by common I meant that the local lumber yard and home center stock several 8.5 blades, and no 7.5
Paul
Ugh. You're being obtuse. 7 1/4 blades work perfectly fine. That's what I was referencing, and yes you can walk in locally and buy them. That wouldn't make a difference to me though, I pretty much order all blades now, and have for quite a while. An Amazon Prime account is well worth it once you realize it saves you time and energy dealing with dumbasses at Home Depot and Lowe's. I go in there for caulking and construction adhesive and that's about it..
when I'm on a job and need a blade, I can't postpone the job several days and wait for a blade from amazon that may or may not show up on time. I need to walk into local homecenter and pick one up, and get back to work.
Paul
Apparently reading comprehension is not a strong suit. 7 1/4 blades work just fine. There are several finish level blades in that size that you can buy at any home center. At least here there are. I don't see why they wouldn't be where you are as well. I don't stop a job for days to order a blade either. I have several on hand in various configurations. It's called being prepared. Never mind - that saw is too complicated for you...
7-1/4 blades are thin kerf for circular saws.
I like a full kerf 7-1/2 FINISH blade.
Do you not understand that?
1 - 20 of 21 Posts
