I can't imagine that...I can't imagine doing it for less.
google up "cabinet construction" and you will find plenty of info on how to put together cabinet boxes.So I don't do bookcases, built ins and what not, in all my years of trim carpentry I have not been on a project that required it nor have I ever had some one ask me to build one.....untill now. These client's want a 10' long x 8' high unit, no back, w/14" cubbies and 2 4' sections coming off the corners w/same cubbies, all painted white... what would you charge to build this??... it would take me to build this would be close to $2k, I can't imagine they would go for this...I can't imagine doing it for less.
Good post by Gus.:thumbsup: I have been asked for things out of my realm of comfortable in the shop. Usually try to put them off until the winter if I can. At least that way when you plan for 3 days and it takes 4 it doesn't sting quite so bad as there are always holes in my winter schedule.Do you have what could be considered shop space that you can do this in?
Do you have a decent table saw with an outfeed table? Good set of straight edges, clamps will also work
Do you have or are you familiar with a cross cut sled for the table saw?
Again a good set of straight edges, clamps will also work
Do you have or are you familiar with a system to drill holes for adjustable shelving? Drilling holes for adjustablity will be cheaper than dadoing rails...Making your own jig shouldn't be too hard.
These things really need a yes answer if it's going to be at all easy. Not impossible with some no's.
Adjustable shelving will be easier than fixed. Which way are you selling it?
"Some of these guys"? :laughing:.....Good luck...that's all I really have to offer....and BTW, some of these guys are real picture whores ~ maybe you can satisfy their itch with some before/during/after type shots?
Sounds more like a large closet shelving unit and less like a bookshelfWow thanks guys, you're going easy on me. I was exspecting..."If you don't know how to do it then don't do it....ya dam newbie!". Well I figured about 18 sheets of 3/4 cab grade ply @ $35 a sheet($630+), rip to 14" x 8' lengths to work with, build on site pre ripped and 1 coat of paint. first stand dividers then tops, pocket screw ledgers at top and bottom between dividers to secure unit to wall, start at the bottom shelf(13 1/4" deep to allow 3/4" toe kick) 5 1/2" up secured to dividers and cleet, nail on toe kick, stand and secure the 14"x14" dividers every 14", then top off each level with 10' lenghts and so on, finish off with 3" crown and 5" base....EH. One day for prefab and paint at home, 2 1/2 days on site to build, =$1700.00 American. The way I look at it is I make $900 in 3 days...still to low.
So really you did it for $1995.00? $5.00 less than your original "estimate". Approximately $1300.00 after materials...Here it is, (5) 9-10hr days, 3/4 mdf, glued and nailed with ledgers in the corners and top, 2 coats. Couldn't take my time cause time is money and I did this for $1895, $600+ in material. Cubbies range from 14 3/4"-15 1/4" to dodge outlets....they will never notice. Ripped all the long dividers off site first. I think prep and paint took me longer than building it, next time I will paint the material first. They love it even tipped me $100.
