I don't like these, but sometimes a customer will pick a cheap genny, that doesn't have a floating neutral.
It's my understanding that if the neutral is bonded at the generator, the transfer equipment will have to be installed as a Separately Derived System.
Because if not, then you will have 2 points where the neutral is bonded, once in the Main, and once in the generator, which, in my opinion, is a no-no. :no:
Which means you can't use an interlock device for Bonded Neutral generators, you need to use a 3-pole double-throw transfer switch to break the neutral.
What say you???
What say you???
