Bluetooth Ear Buds. What features should I be looking for?
1.7K views 10 replies 7 participants last post by  sunkist
I currently use a set of Bluetooth headphones(iso free) as my ear protection. They are a standard set of Bluetooth earbuds with hearing protection. I'm curious if there is a better option for me.
I'm a self employed commercial carpenter that subs on many sites close to or during the finishing stages. I'm also autistic and my mind processes all the sounds at the workplace. When I'm getting tired I become sensitive to the multitude of different sounds. I sometimes use my current ear protection to lesson the number of sounds I hear either by the simple dampening effect from earplugs or by playing bit of music so I just have one audio input(because I really don't care how the electrician's fantasy hockey team is doing).
I originally avoided the noise canceling earbud option, which will probably work better from an Autism perspective, because I was concerned about being told I wasn't able to use them on some sites for safety reasons. An example of this might be failing to hear a scissor lift beep signaling it was moving. Another might be someone communicating something important to you, "Don't step back, passing behind you" ect.
But, features on workplace rated noise canceling earbuds have really exploded over the last couple years and that might make them the best option now. Things an "aware" mode that lets voices through but not sound might do the trick.
If you use noise canceling earbuds what features should I be looking for/avoid from a safety perspective? And which features would you suggest to help deal with my health issues?
#2 ·
Noise cancelling doesn't blank out sound. Not even close. The back up beep will come though no problem. The noise cancelling primarily take care of lower frequency sounds.
#3 ·
Thanks for the info. I've never had a set of noise canceling headphones on so, I'm coming from a place of ignorance. I suspect I need to test a pair to fully understand. I'm imagining different brands will have different ranges of sounds they cancel out? I know some of them can be used to just turn sounds down. Ideally I still want to hear some of my saw, or drill as I use some of those auditory signals to hear if the saw is bogging down, or the drill battery is about to die. But, I don't need to hear the tin basher hammering his tin across the warehouse.
#5 ·
Unless they came out with a break through noise cancelling isn't very effective about 1KHz. I believe they came out for airline passengers who couldn't handle the low frequency tones while in an aircraft and they exploded from there. I have a somewhat cheap set I use in my shop and they work well. But they definitely won't bring sound down to zero
Enlighten me if I'm wrong.
#7 ·
I use over the ear headphones. They have some noise deadening just by doing that even though they aren't ear muffs at all. In my sprayroom with the fan they work great, low frequency. Using the planer they work OK, definitely deaden sound, but ear muffs work better, more high frequency.
#8 · (Edited)
I use the IsoTunes Pro 2.0’s, so that I can pop one out if needed and I won’t lose it. I personally am only really comfortable using an OSHA approved earbud, especially on a commercial site. IsoTunes, Festool, and 3M all make OSHA approved earbuds (I believe). Active noise cancellation will probably be more distracting than passive, since it’ll be changing based on the environment, but not necessarily in the way you want. Damaging frequencies can still pass through ANC, so they’re not as effective as an actual set of hearing protection.
I’d recommend you just keep it simple, and stick with what’s working. I haven’t personally tried any of the Aware line of IsoTunes, since some reviews seemed to indicate that they don’t let sound in at the normal volume, they enhance it until it reaches a dangerous level. If there isn’t something extremely loud happening, you’ll hear all about the electrician’s fantasy hockey team. I’d just look through some of the options I listed above, and see if there’s a different color or case you’d prefer. They’re all pretty comparable to the IsoTunes Free. The Festool is more similar to the Aware, but it seems like the conversation mode can be switched off. Hope this helps!
