Folks,
Okay, I'm learning that low voltage landscape lighting isn't so easy.
I've installed pathway lighting and am having trouble with blown bulbs. The path involves 12 fixtures, each fixtures uses a 12v 20w MR-11 halogen bulb. I'm using 2 circuits wired with 12-2 with 6 fixtures each; the first circuit is 50 feet long with the fixtures distributed equally along its length, the second circuit is 100 feet long with the wire running past the first circuit then picking up the same spacing of the fixtures. Each circuit has a dedicated 12vac electronic transformer rated at 30-150 watts; the bulbs are rated 12v AC/DC. I'm using AC transformers to avoid voltage drop issues associated with DC circuitry, and when the bulbs are working they all seem equally bright. The transformers are mounted in a plastic electrical box in the crawlspace with wires running out to the garden path. Nothing seems to be overheating.
I installed everything, connected up the light switch, and voila - a beautifully illiuminated path... for a few hours. Later that night I noticed a couple of lights were out; some infant mortality on the bulbs I figured. So I replaced them and the next night everything worked fine... but at the end of the night I'd lost 6 bulbs.
Clearly I'm doing something wrong! HELP!! :furious:
Cheers,
TY
Cheers,
TY
