Yep its called experience.I need to support an existing roof with jacks and beams inside dwelling. The roof is comprised of 2x8 at about a 2/12 pitch with no ceiling joists just insulated and drywalled. The beams span about 16' along the roofline, with no mechanicals, plumbing, electrical within the space. I just need to support this roof with jacks and a beam running as close to the existing support structure as possible. Then I can demo the existing windows/wall and continue the block knee wall up to under the 2x8 roof line.
My question is, when I get to the top I need to pour a continuous reinforced beam across the top before adding my top plate PT 2x8. Then, I need to tie in my existing roof (using Simpson ties and toenail with a palm nailer).
If this challenge was a frame wall, it would be no challenge at all. But since it's a block structure, how do I get my roof line to sit exactly where it need to without too much demo?
I'm guessing I'll half to cut at least 3' of drywall back from the outside wall in the house to gain access. I could also tear out the soffit outside...
Is there a technique trick here?
Well said RBS, by the way, how's that pimpin' thing panning out in this economy?:thumbup:Yep its called experience.
Ok lets try this, post your location and name of your company in your profile.Admittedly I've only had 10yrs experience mostly in remodeling and additions. Block work is not foreign to me, but not my expertise my any means. I'm not a homeowner, I don't know how to prove that other than post my GC license # which I won't do. Actually I don't know what pimpin' means in this situation, but business is very good for me and my crew of 2 people. Yes, I'm a young, small, growing remodeling crew. I've been lisenced for 3 yrs.
He is in Florida it probably requires a bond beam.That's better and I do see you have been here since '08.
Since it's Sunday, I believe you are a contractor, and you are correct about the hack part, here goes.
So, if it's a block wall, (8x8x16 I assume) why does it need a continuous reinforced beam at the top? I would think the block wall with the proper footing, solid cap blocks at the top, strap anchors and a TS plate are enough, unless I am missing something.
As far as the wall height, shoot an elevation for the location you want the top of the top plate to be and mark it on a side wall or somewhere it isn't going to be moved or removed. Build your temp wall but use an LVL or other solid beam to span wall to wall. Jack the whole thing up about 1/2" higher than you want to finish at and build your block wall. When you are done, let the temp beam down and the wall will return to it's original elevation.
Same as what you would do if you were replacing rotted porch posts.
Granted, this won't be easy to finish at the exact elevation you need but with careful planning and constant checking as you go up, it should be doable.
At least I know my mason sub can get this done for me :thumbsup:
Exactly what it isCould be.
So what is a bond beam?
Sounds like a formed, reinforced, poured in place kind of lintel.
That would be my assumption. It is usually tied int to the walls as well. Sometimes your rebar runs up inside the walls and ties to the bond beam.Now I am curious as to how this works.
I guess you would need the solid cap block under the hollow CMUs to keep the concrete (or grout) from dropping.
I understand the desire for the continuous beam but is the idea that the poured beam is better bonded to the rest of the masonry?
Pretty interesting. We aren't in a hurricane or high wind area so we don't see that stuff up here.
Kind of what I figured it would be. At least I was on the right track.
This is what I had in mind. I could use "U" block if it's gonna work out that way, or most likely frame and pour exactly what I need. I'm thinking of not using a top plate and just using flashing under my rafters. Then just tapcon my straps to the inside, fur, and drywall.He is in Florida it probably requires a bond beam.
Form up the bond beam with plywood and notch out for the rafters and the plate height. Pour it in place strip the forms and slide the plate in.
