Hey guys we are trying to quote job removing paint off of brick. We do know none of the paint is lead based. It appears to be a latex paint that is flaking really bad. Any suggestions on quoting it? It is 900 sq. ft. first floor only. We will probably setup some containment(tarps on the ground) I figure we will use fine crushed glass. Any guidelines you guys use for this type of blasting? Any other things I should take into consideration? We normally do boat bottoms and in-shop service so this is a bit new to me. Thank you in advance.
