1 - 11 of 11 Posts
Have Trowel, Do travel
I was wondering what actually on how the bids are written out.
since i read here many have difficulty pricing.
I am not interested in the price but more of seeing what your bidding on.
for example i see these types
MASONRY:
for load-bearing walls in seismic areas, external block A05028c thickness of 24 cm, 12 cm thick inner block
Masonry built with bricks with vertical male-female joints, consisting of two blocks with semisolid drilling percentage <= 45%, with an interposed polystyrene panel breathable thickness of 5 cm, total width of 23.5 cm and
A05029 height 19 cm:
for infill walls, external block thickness of 15 cm,
A05029a inner block 12 cm thick
for load-bearing walls in non-seismic zone, the outer block thickness
A05029b 20 cm, 12 cm thick inner block
A05029c thickness of 24 cm, 12 cm thick inner block
Wall built with bricks with vertical tongue and groove joints, consisting of a half-full block the percentage of perforations <= 45% with central holes injected with high density polystyrene foam vapor, total width 23.5 cm, height 19cm.
realize that these have been translated
Discussion Starter · #2 ·
CONCRETE FLOORS
Flooring mixture of reinforced concrete and brick in situ, for planar structures, consisting of pots placed between parallel ridges of asphalt concrete, including the possible formation of ribs in the attics of light distribution in excess of 5.00 m, the joists to support of overlying partitions, bands of flat or countersunk dovetail at the ends of the joists, as well as the burden of formwork, reinforcement provisional support for a maximum height of 4.00m from the floor of the attic soffit, disarmament, and anything else needed to give the finished floor of the art, suitable for the particular purpose requested, excluding the single supply and installation of armor made ​​of iron, with brick composed of a single element (block) with the upper slab
A06001 concrete from 4 cm:
A07. ROOFS AND TINSMITHERY
a thermal insulator in polystyrene graphitized applied, continuously coated with an anti-rust layer. The external sheet which constitutes the sealing element of the package cover is constituted by steel plates to protect multilayer coated on top by a layer anticorrosive and soundproofing a bituminous base and by a lamina of natural aluminum and inferiorly from bituminous primer and aluminum foil . The two plates are connected together with steel plates and spacers ventilating constituted by metal profiles with omega section, suitably slotted to allow the passage of air as required by the UNI 10372. Everything including overlays, hardware and finishing elements consist filled ventilation and micro-perforated edges:
TINSMITHERY- that sounds cool
Plaster, consisting of first scratch coat of the average thickness of 5 mm with pre-packaged coarse mortar with naturally high porosity, hygroscopicity and breathability, consisting of pure natural hydraulic lime NHL 3.5, 5 HL hydraulic lime, natural pozzolan micronized sand and aggregates of siliceous and dolomitic limestone particle size 0 to 2.5 mm, the next two layers of a total thickness of about 15 mm mortar with pure hydraulic lime NHL 3.5, micronized natural pozzolan, aggregates of silica sand and dolomite limestone particle size of 0 to 2.5 mm , final smoothing with plaster skim coat of pure lime NHL 3.5, inert silica sand or dolomitic limestone particle size of 0.1 to 1.4
mm, for a total thickness of 20 mm:
PAINTING WITH PAINT siloxane
Painting with water-based paint based on siloxane resins in aqueous dispersion in matte finish, for external, light-resistant, high permeability to water vapor, applied to
A20018 brush with two hands on support preparation:
A20018a white
A20018b colored
Painting with latex paint based on siloxane resins in water dispersion with a matt finish for restoration and maintenance of external surfaces cavillate, thermal insulation systems, paint and wall coverings in general, highly flexible, water-repellence and vapor permeability, applied with a brush to
A20019 two hands on support preparation:
A20019a white
A20019b colored
PAINTING AND COATING WITH DECORATIVE EFFECTS
Oleosintetico lacquer glaze applied with a brush in three hands after two coats of sealer after preparation of the surface to
A20032 paid separately
Painting the wall with two coats of acrylic paint water matte, washable, applied with a brush after two coats of sealer, after surface preparation to be paid separately in order to have,
A20033 to finished work, a velvety
Decorative coating with both hands to effect multicolor acrylic resins in water dispersion, washable, spray applied after two coats of sealer after preparation of the
A20034 surface to be paid separately
Decorative coating spatula effect based on acrylic resins in water dispersion, washable, made ​​with two coats with a spatula after two hands insulating, after
A20035 preparation of the surface to be paid separately
With slightly textured coating paint made ​​from milk of lime and organic ligands, with cloudy effect or brushed by brush application of two coats of primer and next coat of glaze sponge trowel or brush,
A20036 on suitable substrate
Polished Venetian stucco coating type, two coats of primer and two finishing trowel applied after a coat of primer on
A20037 surface properly prepared to be paid separately Finish transparent protective coating stucco type
A20038 Venetian applied with a brush
Decorative coating stucco based mineral slaked lime applied after a coat of primer and insulating
A20039 surface previously prepared, to be paid in part:
A20039a effect lime coated, applied with a brush
A20039b effect polished plaster, applied with a trowel
A20039c marble effect, applied with a trowel
Discussion Starter · #11 ·
Are you taking this from a database you have created yourself, or are you finding these in another place on the internet or in a book?
these come from the last bid i did.
i know they are "a little" off in the translation, but, basically everything is there to make a bid
1 - 11 of 11 Posts
