1 - 20 of 28 Posts
I've got a family member who wants to have a silo demoed. I've got an idea how I'm going to go about it...what would you do? I'd be using a TLB. The silo is roughly 30-40' tall made of interlocking concrete blocks and metal bands. The top is open.
I did one once, and saved the interlocking bricks to use as pavers. Really neat.
If your goal is to salvage the material, get a bucket truck, or boom lift. If you simply want it down safely, use a long steel cable, cinched around the silo, maybe 6 feet up, and far enough away to keep out of a possible debris field, and winch or pull....and it will take some power. Cutting it with a cable should make it fall into it's own footprint, more or less...and don't forget a picture for us.
Chief outhouse engineer
Torch the rings, leaving approximately every third ring. Then knock out the bottom like dropping a tree. Did one ninety feet tall about 25 years ago. Came down like a ton of bricks.:clap:
I found that a tlb is too slow to get out of the way if it doesn't feel right. I've done them with a sledge hammer just knocking out one row until it starts to creak, stand back annd watch it fall.
Something like this?
Thinking about taking this down, but it's poured concrete. Walls are about 2' thick near the bottom and thin out as it rises.
Discussion Starter · #12 ·
That's really the one thing making me uneasy...I figured I'd knock out a few blocks on the side I wanted it to fall to and push or pull it that way with the backhoe. If things went wrong I wouldn't be able to get out of the way of it falling. I'll probably just do as you said, keep knocking blocks out until it falls on its own.
If I had a long steel cable "cutting" it would be the easiest way though I question whether I would get enough traction and or power to pull through it with my tlb.
One of them that I did was already leaning real bad, so I thought I could just reach high up with the backhoe and push it over, well it just slid over 10' or so and collapsed about 10'. So now I had a 30' tall silo standing straighter than it was when I got there and I had the foundation etc. between the tlb and the silo so I couldn't reach very high at all. That was why I got out the sledge and started swinging.
Master of the Underground
It's an expansive grout to fracture concrete, rock, or masonary
would this work on a poured wall silo? Maybe if drilling holes? I will try and get a picture of this tomorrow or sunday. its similar to what bill z posted but taller and only a 10'x10' hole at the bottom and an open top.
Dig with BIG TOYS
dexpan would probably work really well for this... put it in half of the circle and watch the whole thing come down. I know from experience that **** really dose a good job... they use it to mine granite in the quarries so im sure that this silo woudnt be to big a challenge
Al Smith
But arent the masonry units that were used in the above silo videos hollow? How would you use dexpan in the above examples?
1 - 20 of 28 Posts
