1 - 19 of 19 Posts
What would be the best way to remove some tile in a store entranceway? They are applied to a concrete slab and need to be replaced with new flat black tiles. Any help would be appreciated.
I know the hand chisel and hammer method.
I would show a pic but I need 15 posts before I can do that.
Richard
· Banned
$29 air impact with a wide chisel bit hooked up to a good sized air compressor.
Electric $300 rotary hammer drill with a wide chisel bit.
Both will do the job, the first one will take you 2x as long as the 2nd one.
· Contractor
I don't want to surprise you with this, but there is a tile removing tool sold in Lowes (maybe HD)-long handle with a thick flat blade on it for scraping. Works wonders w/ VCT-not sure how it would do w/ a ceramic tile. it being a commercial setting, I'm guessing it's VCT.
Ive always used sweat and blood with tears and elbow grease... perfect concoction.... for large areas tho? maybe call for a blood transfusion about evry hour or so.... and drink plenty of water. Never had the need to do large areas, thank god.... look at my method... i'd be dead. the electric deal sounds promising.... can u rent one of those? I think i would. Good luck
Mike's way is cleanest with less bs. I used to use a grinder and diamond wheel when dust wasn't an issue. BUT BOY HOWDIE did dust fly.
Use the spade chisels he suggested on the grout as close to the tiles to be removed and pound on the tile with a dead blow hammer.
MAKE SURE you go threw the thinset to the concrete or you will be replacing more tile. NOT that I would know!:whistling
Oh BTW I've been to the Hooters in Willmington if that's the "store" you're doing it at I can fly up 95 and be there to start first thing in the Morn. and show you what I mean!:thumbup:
Mike finley has got the tried and true meathod
:thumbup: A Rental store will also have a floor grinder(ordinary buffer with carborundum stones) to remove old firmset.
Worth the rental if the area is large enough. MIKE
· Super Moderator
You can rent an air powered "pogo stick" from most rental places for the really hard to remove ones. Makes a big mess and you will need a gas compressor, but it works well usually. We, like others have tried all the methods. Depends on the situation. Couple of times we had tile over a mesh/mortar bed and had to cut out 2x2 sections and used a roofers shingle lifter to pry them up.
Discussion Starter · #13 ·
Thanks, y'all
I am impressed with all the response I received. Good info.:thumbup:
I am going with the rotary hammer drill and wide chisel bit. I think it will take care of my needs the best.
Richard
· Carpe Diem
How do you like that Bosch extractor with thier concrete grinder?
I like it....especially for the price. I bought the grinder new but found the vacuum used. I still quarantine off the area I'm working in but there's A LOT less dust.
I have been doing quite a few jobs the past 2 years when I have to pull old tile off concrete. I can do a 5'x8' area from original tile to ready for new tile in a few hours.
:notworthy getting to give good advice to a real handyman, you are a God to me. I would take a bucket of muratic acid and pour in the area where you want your tiles removed, be sure to surround area with those acid resistant rags. Pretty soon your tiles will just lift up, now get some gorilla glue and spread on floor and just lay in your new tile. I use this method all the time, anyone can do it, that why we are called professionals.
Discussion Starter · #17 ·
Wow, I am really impressed.
You should contact HD and see if you can get into there updated "How To Do It" construction manual. I bet they would also be impressed.
Actually, the name of my company is #1 Handyman Service.
I prefer to do two or three little jobs a day rather than one big job that lasts a week or more. Filling up a week with small jobs can be more lucrative than one job and it is real easy to leave it at work and not bring it home. I have no official employees or all the paperwork involved with them. To solve the problem of working alone I do have some people to call on when I need the help. Generally though, it is just me.
· Project Manager HFH..
Just "unofficial" ones that you give 80.00 to at the end of the day and then drop them back off in front of HD?:laughing:
1 - 19 of 19 Posts
