1 - 5 of 5 Posts
Best way to install 3/4" Insulated glass & 1/2" stained glass in one opening
Ok, This is a strange request. I have an opening on a 6" stud wall that is getting both a 3/4" low e piece of glass and a 1/2" piece of stained glass in it. The purpose of the low e is to help the r value of the window. Not sure which piece should go on the inside of the house and which should go on the outside and the best way to space them out. What would be the best way to install this to prevent condensation? This is in Arkansas which can be very humid and hot. Thanks in advance.
I'm not a glass installer but I would put the low e on the outside giving the stained glass protection. Then I would only separate it 3/4" to 7/8" the farther away I would think the more it would obscure the view of the stained glass.
Maybe you can have a shop incase the 2 in an aluminum or vinyl airtight frame.
Builder/Remodeler
Andersen art glass installs on the inside of the insulated sash.
I installed one several years ago and it's never had a condensation problem. We get very hot humid summers and subzero winters:
1 - 5 of 5 Posts
