A band saw with a taper jig get's my vote.
Can't get a porta-band saw that will cut 12". I'd be worried that the blade would wander over 12" as well.A band saw with a taper jig get's my vote.
Exactly what I was thinking.I'd make a router jig using guide rails at your 9 degrees.
Exactly what i was thinking.I'll bet Bass has done goofier things than this. Hope he's got time to offer a suggestion.
Me to! I'm not sue if I could find a 12" long router bit.I'd make a router jig using guide rails at your 9 degrees. Then a really big plate for the router. Could take more time to set up the jig than it took you to make that beautiful cap. I'll bet Bass has done goofier things than this. Hope he's got time to offer a suggestion.
MIKE
Yup, Let me find them. Be right back.Got a pic of the old connections from the rail to the cap?![]()
You wouldn't need a 12", just a 3/4".Me to! I'm not sue if I could find a 12" long router bit.
Some of the rails and caps were done that way. I think the one's in the picture above were done that way and they all tended to open up and let water into the balustrades and then rotted them out.Hmm. Stoopid maybe, but trying to think outside the box. How about cutting the cap rather than the rail? That way you wouldn't have feather edges.
Yes, that does make sense. Okay, use your coping saw. :thumbsup::jester:The one's that were coped held up much better so we want to go that way this time around.
No doubt that a belt sander will be used in the "fine tuning":shifty: no matter how we end up cutting it.I would like to offer up a scientific approach to that cut, however i would probably end up using my circular saw and my belt sander, the first few would be a little slow going, by the last one i would be a champ, G
Damn! I under bid this one if I have to go that route!:jester::laughing:
MIKE
