Absolutely nothing wrong with that. Junction boxes are required to be accessible so that if anything ever goes wrong with the junction, it can be repaired.I am sure you dont mean to leave live wiring in the ceiling with no jbox access :whistling
Certainly. Live wires are concealed behind drywall everywhere. What is the safety concern with a properly capped wire that just happens to stop dead between a couple of studs?So, you're saying you would just put wire nuts on live wires and conceal them behind drywall?
My OCD could give you lots of reasons. :whistling Whether they make sense or not, well it is OCD after all.Certainly. Live wires are concealed behind drywall everywhere. What is the safety concern with a properly capped wire that just happens to stop dead between a couple of studs?
I'm honestly interested in hearing if you can come up with one.
I don't think the OP stated if the wires would be dead or if it powered other lights. Live or powering other lights would require a box and must be accessible.Certainly. Live wires are concealed behind drywall everywhere. What is the safety concern with a properly capped wire that just happens to stop dead between a couple of studs?
Tin... you are making me rethink life...Certainly. Live wires are concealed behind drywall everywhere. What is the safety concern with a properly capped wire that just happens to stop dead between a couple of studs?
Then you would have to surface-mount conduit everywhere you work. All modern houses have live wires sitting behind drywall.I couldn't just leave lives wires sitting behind drywall.
But those are all connected inside boxes, you can't have live wires just terminated inside a wall without being within a box. And if it's in a box it has to accessible. At least that's the way I know it to be.Then you would have to surface-mount conduit everywhere you work. All modern houses have live wires sitting behind drywall.
If I'm opening a wall, etc. and I find that, I know the previous guy didn't give a chit about anybody but himself. It's unsafe. I can imagine it laying against the backside of the ceiling to be found by the next plumber, electrician, whoever, with his tool in hand. Also, I don't need to "find" a live wire, capped or not, with an exposed ground close at hand. Dangerous. And that box offers a little bit of protection from the dopes that think they know how to cap a wire...but really don't.I get the OCD bit; I suffer from that as well. But sometimes an exposed j-box is just plain unacceptable in that location, and it's economically unfeasible to spend the time and mayhem chasing down the other end of the wire to disconnect it there.
Again, where's the safety hazard?
You can sleep all you want but you won't come up with a good answer.I'm sure I could think of plenty of I was less tired and it was earlier. But, I would never do it. I would trace the wire and disconnect it at the source first. That is not as hard as it may seem because all of the junction boxes are exposed: process of elimination.
Also, I would hate to leave the live wire in there and have the next guy come upon it by a shocking surprise. Screw that.
If a conspicuous cover is unacceptable, I would trace and disconnect. Or, not do the job at all.
I couldn't just leave lives wires sitting behind drywall. And frankly, I didn't think you could or would either until now.
