Why does your vac have unsealed areas? Time to get a decent vac. You really should have an RRP compliant vac with a good amount of power. My suggestion is to get a new vac not filter.
RRP eh? Don't think he needs that.Why does your vac have unsealed areas? Time to get a decent vac. You really should have an RRP compliant vac with a good amount of power. My suggestion is to get a new vac not filter.
This thing is very powerful. I got it about 2 years ago because it is compact. I don't know much about it though.Why does your vac have unsealed areas? Time to get a decent vac. You really should have an RRP compliant vac with a good amount of power. My suggestion is to get a new vac not filter.
Bag reduces flow and thus suction. Not sure that's the desired result. RRP is simply a sealed system. If his vac is leaking, no matter what you use, it will end up throwing dust (any that remains in the canister).RRP eh? Don't think he needs that.
Just use bags.
Bags help maintain suction because the filter doesn't clog in 30 seconds.Bag reduces flow and thus suction. Not sure that's the desired result. RRP is simply a sealed system. If his vac is leaking, no matter what you use, it will end up throwing dust (any that remains in the canister).
While that is true, it doesn't negate the fact that the vac has to draw air through the bag, thus reducing overall performance. Also the bag isn't impervious to dust. It will clog rather quickly.Bags help maintain suction because the filter doesn't clog in 30 seconds.
And are cheap.:whistling
I wasn't suggesting that it doesn't, just saying that when you purchase a good HEPA vac make sure that you don't chince on the power.This thing is very powerful. I got it about 2 years ago because it is compact. I don't know much about it though.
This is the unit I have (pic pulled from the net)
I own the small 5 gallon and the thing sucks.The rigid vacs any good? there always seems to be promotions on them and HD.
In a good wayI own the small 5 gallon and the thing sucks.
I only have experience with one rigid vac and while the suction was great, the thing was as loud as a harrier jet during a vertical takeoff.The rigid vacs any good? there always seems to be promotions on them and HD.
I don't think so.The rigid vacs any good? there always seems to be promotions on them and HD.
They are probably the best shop-vac-style shop vacs out there before you cross over to full unit HEPA vacs. I have the bigger Ridgid with a cleanstream filter, muffler and only use it with bags. For the price, it performs well and has a ton of capacity.The rigid vacs any good? there always seems to be promotions on them and HD.
