1 - 20 of 23 Posts
You can try a whisk broom, use regular mud not the lightweight variety. I would practice on a piece of drywall and you'll have to mix it with water to find the right consistency.
I have this in my house only it's mixed with sand and it's perfectly symmetrical. You'll never match it perfectly, the pattern of the broom will be different.
Drywall, Texturing and Painting
Drywall Slave
YES ...They all interlock . Very hard to match up.
justanotherdrywaller
led double strip on both sides .when I put molding up to hide the light I confined the light to follow the surface. looked like a beginner did the ceiling.i knifed a tight swirl,2 coats,corrected all imperfections.
Discussion Starter · #16 ·
So im working on this fish scale texture. I can match the pattern but am having trouble with the mud clumping up. Any suggestion what im doing wrong. I tried thinning it and also heavy mud. Or can I let it dry like that and get the chucks off
Wood Wood flooring Plywood Floor Pattern
Drywall Slave
Keep a bucket of water close by ..Slosh your brush in the water then sling it clean on a piece of scrap rock or plastic every so often ..That helps .
Also ..Don't get too far ahead of yourself before you start to swirl The mud will start to dry on ya.
Home Repairs
Jason....... I tried to respond to your message but it will not send for some reason. Here is a pic of what I use to create that same float.
Lowes sells these "medium size pours" sponges in the cleaning ailse. All I do is take a pair of scissors and nip off the leading edge of the sponge. (round it over) Just nip the long edges. As you can see in the picture......I'm not taking off much. This will prevent the sponge from plowing the material. As the sponge rides over the material the some pours will collapse and leave the same texture that you are looking for. You will light pressure to the trailing edge only. Done let the front edge touch the material. I prefer to use 45 minute hot mud for this type of repair because it comes out slick like your original pic.
You can cut the length of the sponge to copy the size of the original swirls. This sponge in the picture is not full size.
1 - 20 of 23 Posts
